Chapter 10) TEMPEST DISPLAY troubleshooting (flowchart)
This flowchart is excerpted from a photocopy of a photocopy (of a...) which has no visible attribution or copyright. It appears to be from the Star*Tech Journal but I don't know for sure and the guy who sent it to me doesn't know where it came from.
====================START====================
Most problems in the Tempest display can be found by following the procedure shown in the chart below.
CAUTION: When replacing the transistors mounted on the chassis, make sure the pins do not short to the chassis. If the chart procedures do not solve your problem, call Atari Field Service [NOTE: They will be of little help nowadays :>].
[NOTE: I have taken considerable liberty in restructuring the flow and rewriting the text in order to be more clear than the original chart and to better fit in 80 column text format. I have added a couple of things, too.]
No picture and...
+--------YES---- 5 amp fuse (F100 or F101)----NO-------+
| on Deflection PCB blows? |
Cannot get/keep +/- 28 Volts. Turn up brightness and contrast controls
Disconnect P600, P700, and<--------+ on HV PCB. Is there a dot in the center
P100. Power up monitor. | of the screen?-----------------+
|/ | NO | | | YES |
Fuse still blows?-------NO-------+ | |/ |/ | |/
| | | Is there +/- 28V on | Is there 180V on
YES | | | on pins 1/8 of P900? | pin 5 of P900?
Replace the following components | | NO | YES | +-----+ YES | NO
if shorted: D100, D101, D102, | | | | |
D103, C100, and C101 | +--------+ +----------------------+
|/ Change or make sure C901 and C902 are
Check for Q102/3 collector short to 100uF at 50 volts. Check for a leaky
chassis. Replace the following compo- C905. If C905 is bad, also check or
nents if defective: Q100, Q101, D104, replace Q900, Q901, Q902, Q903. Is
D105, ZD100, ZD101, Q102, and Q103. there 180 volts on pin 5 of P900 now?-+
|/ NO | YES |
Connect P100 and power up. Is | |
the +/- 28V on pins 4/5 of P100 Check resistors R100, | |
OK now?--+--------------NO------------->R101, R102, and R103 | |
| for open circuits. | |
YES | | | |
Replace the following components | |/ |
if defective: Q603, Q605, Q606,<---+ Double-check the above transistors. |
Q703, Q705, Q706. Also look for burnt (open or shorted) |
| resistors R903, R904, R905, R906, or |
|/ R907. | |
Connect P600 and P700 and power | |
up. Picture now?-------YES--------+---------------------+--------------------+
NO | | Is picture "blooming" (does the image
|/ +--->appear as though being viewed through
Check remaining transistors | a magnifying glass)? |
in the X and Y amplifiers. | | |
Then make sure the following-------+ NO | YES |
resistors are not open: R702, |/ |/
R703, R711, R712, R602, R603, >END<----Replace ZD902 on HV PCB.
R611, and R612. /
====================STOP=====================
