Tempest not saving scores
DanP
Administrator
2,232CR
Steve, put it into test mode and see if you have a 'E' error. It's probably either the EAROM (2055) or the voltages it needs aren't right. IIRC it needs the +/- 22v supply to be right or it won't work. There are I believe some modern replacements that don't need those funky voltages.
smarty
Ready Player One
1,305CR
Phil Murr does a modern drop in replacement. that doesn’t need the odd ball minus voltage to work. I’ve used one on a centipede PCB in the past.
philmurr
48 (100%)
2,378CR
Check on the AR2 to see if you're getting the -22V supply (white/brown wire going to pin 3 of connector P10). That should be ok as the same supply also feeds the -5V rail.
If that's ok check pin 14 of the EAROM (should be -28V). If it isn't then there's a problem with the charge pump circuit that generates -28V from -22V. If the voltage is ok then it may be a faulty EAROM or the circuit that selects/buffers it.
If you're happy to solder it up I can put an EAROM replacement PCB in the post to you.
bonehead
I'll get pix tonight
50 (100%)
1,729CR
Small update-
Switched the cab on this morning and it has kept the score from last night. No errors in test mode.
I will see what happens over the weekend.
Thanks for your kind offer phil, happy to have a go at it but should I wait and see if it’s now keeping the higher scores?
Steve
