Tempest PCB
Zektor
312CR
I've had this sitting around for years now, originally purchased on ebay (USA)
Upon power up I noticed the power reset circuit had the 10.6v missing, I only have the loom and from looking at the schematics the coin door needs to be plugged in for it to loop to the PCB. Anyway after sorting that, I found an address line of ls244 at BC1 pin 16 (AB2) stuck low. This is one of the address lines for the program Ram and Rom.
That's as far as I got today, hopefully remove the 2 RAM chips tomorrow and see what's what.
Zektor
312CR
Ok so I found the 74244 ac B/C1 was faulty, pin 7 tied to ground. Powered up and now I get more activity on the data and address lines with the Watchdog disable tab grounded. I found another faulty 74244 at A/B1, replaced and now the CPU is running without Watchdog disable tab grounded.
I have another problem now in that the loom I'm using seems to wired incorrectly....I have no - / + 22 volts to the main PCB. The PCB connectors 3 and 4 have 2 small white wires running to the 5v side of the AR2......I'm pretty sure its a tempest loom as it came with the spinner and buttons still attached. If anyone here with a Tempest could take a pic of the AR2 connectors and PCB connectors I would very much appreciate it.
Here are a few shots of mine, only one set of wires coming from the 22v side of the AR2 :-/
Monstermug
1,804CR
From the schematics, +22v comes out of pins 1 and 2 (J10) of the AR2, while -22v comes out of pins 3 and 6 (J10). If you're not getting +/-22v from those pins on the AR2 then check the bridge rectifier and/or caps at C18 and C19 and if you are getting 36vac from the power brick. While you at it check if R32 is 5.6k too.
+22v and -22v from those pins should go directly to X/3 and W/4 respectively on the 44 Pin edge and 3/P and 4/N on the 30 pin aux board. From memory, +22v and -22v have link traces that runs to the other side of the board so there may probably be only one wire for each.
Zektor
312CR
The AR2 is known good.....I'm getting + and -22 on the Aux Board.
I just checked the harness part number...arghhh I was sold a Star wars harness with a Tempest spinner and buttons plugged into it :))
So I now have 3 complete star wars harnesses...time to hit the for sale and wanted section.
Zektor
312CR
More progress on this. I spent the day setting up my KK TF650 test unit. I knew I had 2 of the 3 cards needed to run a tempest PCB and managed to make the 3rd using a straight through 25pin card and a 22 pin adaptor.
The PCB will run now, I can hear sounds but haven't confirmed any video output, I need to make an adaptor for my ZVG vector to LCD unit.
Here's a shot video of the KK unit.
https://www.youtube.com/watch?v=tggnIaH2wJAZektor2017-04-08 21:14:00
Zektor
312CR
More progress on this today, man this was a bitch to fix.
I found a bad trace on the underside and along with replacing a flaky D7 PROM socket the board starting showing more signs of life. It was still far from "working" but I could see parts of the Vector Data at the DACS. I found a dead MC1495 in the XY output stage, hooked up my scope and got a weird curved line on the display.....only in test mode, game mode was still playing blind.
After a lot of testing I found the Stack and program counters were static due to OP0 being static. Pin 3(op0) of D7 Prom was static and in turn LATCH2 and Strobe2 were inactive. I checked the Prom by reading it as a 74288 in my chip tester and comparing it to the Prom in Space duel.
I eventually found a stuck output on pin6 of B9(74ls32)this was stopping the AVG0 signal from being generated which allowed the game to play blind and not cause a reset, pulled the chip and sure enough it was dead. Fitted a new chip and Bingo!! it lives!!Zektor2017-04-24 11:37:22
Zektor
312CR
