Tempest spinner with JRok
PhilT
154CR
Hi
Anyone here familiar with jrok cards and the spinner input? I just cant get Mad Planets ship to turn in the opposite direction.
Got a tempest spinner, checked, all works, clk and dir lines are toggling between 0 an 4.8v when the spinner is turned. Hook it up to the jrok card spinner lines and the ship will only every rotate in 1 direction regardless of which way the spinner is turned.
Set delay to 3 (72 clicks per rotation) / played with setting, just wont work. Totally frustrated and out of ideas now. Anyone else experienced such a thing and more importantly, how did you fix it?
PhilT
PhilT
154CR
quick update for future reference. This seems to be a bit of a common issue with no definitive solution. Heres what worked for me which is not written up anywhere else I can find.
My tempest spinner was a reproduction, it had optics that you would find on a steering wheel setup so the optics were positioned in a single unit in an arch arrangement. The encoded wheel spun between the optics just fine and appeared to be functional, but playing mad planets on a jrok card, the ship would only every rotate in one direction.
Jrok card is not at fault, just ensure spinner is enabled within settings. Spinner needed modification.
Problem 1
Because of the arch arrangement of the optics, there was a large air-gap between sender and receiver where the encoder wheel ran.
This caused the lowest voltage, with the spinner in a totally closed position, to be around 1.2v. Technically low enough for a logical low state, but because of this, the line pulses go low later and go high earlier, giving a much longer (or shorter depending on how its viewed) pulse, this throws out the phasing between the speed and direction line pulses == ship only spins in 1 direction.
Replace the steering wheel optics unit with a pair of H221A optics. This much reduces the air-gap and takes the low state voltage down to ~0v
Problem 2
The distance between the pair of optics is critical to correct operation. Too close together throws out the speed and direction pulse phasing == ship only spins in 1 direction. We are talking millimetres here. I had to tweak the distance to get direction working, made more difficult by the existing pcb mounting holes not being exactly in the right place.
Anyway hope that helps someone sometime.
