Tempest troubles
t-m
333CR
I’m looking at a problem with the Tempest that lives at the Computing History museum, it’s been working for a good few months now but now it’s developed a fault so any pointers very welcome.
What’s happening is the game is playing but the picture has collapsed to the bottom corner of the screen, it’s flipped vertically and half is squashed/not visible. In test mode you can’t see the full screen but the game sounds one solid tone.
I’ve checked the AR2 voltages ok and the board voltages +5/+15/-15v are ok, now I’m a bit stuck!
Syrup2407
163CR
Hi T-M,
If the DACs are socketed on the board can you swap these to see if this changes the fault?
I am pretty local to Cambridge (I live near to Ely) and have a Tempest. I am happy to try my board in the machine or to try the duff board in my machine / swap some of the chips etc. to help diagnose the issues.
I also have an old oscilloscope we can put into X-Y mode to look at the output pre-monitor. Just let me know if I can help.
Cheers,
Gav
t-m
333CR
Thanks all. Gav if I could test the board on your machine that would be helpful then if it's OK then I can look at the monitor transistors next time i'm there.
I could connect it to my 'scope but I don't have a AR2/brick to power it, is it possible to power it with a switch mode psu or something for the purposes of testing?
For reference this is what it looks like...
karlcdoe
887CR
from your photo: probably a failed deflection transistor. sometime the connectors to the chassis mounts simply make bad contact. bit suspect that it is flipped though.
from you decription: I'd have said a failing DAC :)
from test mode: one solid tone or a short 'beep'?
karlcdoe2018-01-12 12:49:36
t-m
333CR
Thanks, good job I uploaded a picture!
It makes one continuous solid tone, changes as you'd expect when you push buttons.
tb lilley
5 Star
1,686CR
Might have more than one problem there. Thoughts:
- as above, failed deflection transistor would explain partial screen collapse
- looks as though the board thinks it's half in / half out of a cocktail (screen half inverted). Check POKEY not playing up and inverting on only one axis (shouldn't be inverting on either ..)
karlcdoe
887CR
I just tried this to be sure.
I put the test switch on: it goes silently to the test screen.
I hit slam tilt: it made one continuous tone.
I pressed fire and zap for self test: it silently went to the screen showing the dip status amd beeps briefly when I press any switches (I thought it beeped briefly on entering menu for some reason).
So, if you are getting one long tone on entering self test then the manual says check ram at R2,AVG PCB. Assuming you could see the screen properly it might also display the location of the suspect chip. Having said that the spot killer usually trips in on my Tempest when I've had bad RAMS but I can't recall which ones I've had fail so YMMV.
t-m
333CR
Thanks all. I managed to get back yesterday and have a look. All the deflection transistors on the chassis check out ok, not that I'm totally going to rule out the monitor though as there's clearly been some bodges in there that needs sorting and some preventative maintenance on it wouldn't go a miss I think.
So maybe we're looking at DACs/other board fault... I'll try and get the board tested separately and see.
Syrup2407
163CR
Latest update on the Tempest board from the Muesuem.
I picked up the board from t-m and (leaving him with mine to try in the museums cab so we can see if the deflection, HV and monitor have any other issues) and I can confirm that the same issue is present when the board is put into my cab. (This image is squashed in the bottom left corner and the picture is reversed in one axis). (Interestingly the image is not reversed when a scope is connected to the x-y outputs of the board).
On checking the voltages the 6.8V line is low (at about 3V). This is an indicator of an issue in the analog circuitry pulling down the 6.8V supply. As one of SG1495 chips is nice and toasty I am gueesing this could be part of the issue.
If I get time today I will pull the toasty chip and see if this restores the 6.8V supply (more than one chip sits on this supply so there may be others that need replacing). I need to get a few of these chips on order before I can fit a new one, when these arrive I will report back with more info.
Cheers,
Gav
Syrup2407
163CR
Thanks Steve, I think I am looking in the right place but as you know these Vectors can be tricky at the best of times!
Does anyone know of a UK stockist for the MC1495 or even 1595's. It looks like it will be a few weeks to get em from China otherwise.
Cheers,
Gav
Syrup2407
163CR
Hi Jon,
Thanks for the heads up but Mouser are showing the part as no longer stocked.
Have ordered a bunch from China so am expecting them in a month from now.....
Cheers,
Gav
karlcdoe
887CR
I usually get mine from arcadechips, they have gradually gone up in price since my first order though. Looking briefly at farnell not sure if there is a modern alternative such as there is for the DAC, but you never know.
Syrup2407
163CR
Hi Karl,
Arcadechips do have some stock but they are quite expensive once you include the shipping/
I have placed an order for some parts from China (£1.71 each plus free shipping), but will take a few weeks to get here, I will just have to be patient I guess!
Ta,
Gav
Syrup2407
163CR
Hi all,
I have spent a little more time on the Tempest game board from the computer museum cabinet and I am happy to report that it is now up and running.
I removed the MC1495 multiplier that was pulling down the 6.8V supply and once removed the supply returned to 6.7V (close enough for a zener). I put a socket in place of the chip and had a ferret through my components boxes. I got lucky and found an MC1495 which I promptly inserted into the socket.
When I fired up the game I was greeted with the sight of lots of lovely vectors, this time they are the right way round and not restricted to the bottom left corner of the screen.
I will leave the board running tomorrow to burn in the new chip and see if anything else goes awry.
T-M has been looking at the cabinet at the museum and I will leave it to him to give update on the work he will be putting into the monitor boards.
Looks like the Tempest will be up and running in time for the meet later in the year.
Cheers,
Gav
