Test rom information
philmurr
48 (100%)
2,382CR
The test ROM performs the following tests:-
1 - programme RAM (7P & 7N) - flashes "testing RAM don't worry" otherwise it looks like nothing is happening. If it fails it displays the address it failed at, and stops further tests
2 - object RAM (4F & 5F) - if it fails it says "ORAM stuffed"
3 - video RAM (3F & 3H) - if it fails it says "VRAM stuffed"
4 - sprites - you can't read the sprite RAM so it drops sprites down the screen until all 7.5 are showing. If you don't see 1-7.5 full colour sprites moving smoothly you have an issue there
5 - DIPs and inputs - displays the status of DIP switches and inputs in real time
4 & 5 depend on which version of test ROM you have, they've only recently been added
Note just because the test ROM says certain RAM is faulty, it doesn't necessarily mean the RAM chips themselves are faulty but could be (and usually is) the supporting circuit
Thank you for that phil.
If i have the first RAM test fail and this gives numbers at the top of the screen like 4000 40 42 , how do interpret these ?
Robin
I only quoted those numbers because there the only fail ram test numbers i`ve seen on a test rom.
I don't really understand how these game boards work , its one thing to know how AND and NOR gates work and something else how the ram talks to the roms.
Am write in thinking you really need one of those fluke testers that plug into the micro p socket to understand what the test rom is telling you ?
Robin
