You need to grab a cheap-ish multi-meter with capacitance. They are quite good these days.
Even then measuring in circuit is not perfect as there will be other components (probably including other caps) in parallel with the cap your trying to read. Caps in parallel ADD to the total capacitance. So, for example, if your trying to test a 470uF in circuit and it reads 650uF then it 'might' be OK. But if it reads 300uF then it's almost certainly screwed.
The exact opposite is true for resisters.
Always better to remove / replace.
Apologies if you already know this. Not trying to teach you to suck eggs.
Ropi Jo2019-10-06 20:25:57
