Thawing out an Arcade Machine
neoretro
1,121CR
Hi all,
Just brought one of my arcade machines inside and upstairs after spending all winter in the garage which isn’t heated.
It’s an MVS U4 so the metal gets quite cold. It’s in and I’ve opened all the doors to let the warmth in and any moisture out.
I was wondering how long should I leave it before turning her on?
Dave
penrhos
747CR
A good couple of days at least. I'd run a fan to circulate warm air through the cab. Biggest problem will be damp on the lopt and tube due to HT.
Unless your house is cold a fan heater shouldn't be required and if there was too much temp difference it could damage stuff. Far better to gradually bring it up to room temperature with plenty of air circulation to evaporate and moisture.
RaveN
1,325CR
Depends how cold it was. Most electronics will quite happily work within wide temperature ranges, but it's things like solder joints that tend to fail with temperature changes with expansion. IC's probably won't fail, but old, abused monitors might suffer.
Flinnster
The Dino King
29 (100%)
2,566CR
Yeah, fan, central heating, dehumidifier, and a decent amount of time.
I normally leave wet stripped electronics / pcbs in a hot airing cupboard for a full 48 hours before reassembly and that's stuff with socketed chips removed and connectors separated.
For a full cab I think patience is key. I screwed a CRT back in 1994 due to condensation and my own stubborn impatience. Lesson learnt.
neoretro
1,121CR
Thanks everyone.
General consensus seems to be at least a few days. So I will probably make an attempt on it on Monday night.
Have got a dehumidifier which I’ll put at the door of the machine. Not keen on using a heated fan incase a sudden change in temperature upsets something. Will post results.
neoretro
1,121CR
gunblade said:
the worry would be damp in the monitor
Cheers Grant. The garage is actually fairly dry. Insulated door and roof etc. Is there any way you can recommend, other than what I’ve mentioned, that I could help avoid that?
gunblade
9,149CR
hairdryer, not too hot or too close- around anode cap and deflection coils in particular
if it was dry then its unlikely to be an issue, just leave for a few days before powering on
penrhos
747CR
I'd open the monitor glass door and leave it open as at the moment any moisture will be trapped in the top of the cab as no thoough-airflow.penrhos2019-01-25 10:42:31
neoretro
1,121CR
I was going to put a cold air fan at the front later to encourage it to blow it out the back which is removed.
Any idea which lock releases the monitor hatch? Is it the control panel down then lift the monitor?
penrhos
747CR
Unlock the control panel, it hinges open and you should be able to release the screen cover, it'll hinge upwards mine had a lock- bar to keep it open.
