ThunderBlade on AfterBurner Hardware Patch
dj_yt
787CR
Here's a quick EPROM patch, so that ThunderBlade can be run on AfterBurner hardware without rewiring the controls.
Usually the X-Axis controls are inverted, so you'd have to change the wiring in the cabinet.
In theory this should make the two boardsets easily swapable.
I haven't tested this on hardware yet, only emulation. But there's no reason it shouldn't work.
https://drive.google.com/file/d/1emsvrIPk0bPxUtTuyxyaR1GwhQSHREbG/view?usp=sharing
smarty
Ready Player One
1,296CR
Nice work Chris. That’s a good mod for hobbyists with an AB cab.
How about a mod to play both games from one board?
smarty2018-10-09 06:33:46
dj_yt
787CR
I'll leave that one to the professionals!
It's bizarre that the control wiring is identical to Afterburner aside from the X axis. I wonder if this was a mistake by sega or intentional, especially as some thunderblade uprights were identical to Afterburner bar the artwork.
smarty
Ready Player One
1,296CR
It is odd considering all the Mini Sega cabs you see which started life as Afterburner and were converted to Thunderblade. But then I suppose an op wouldn’t complian at cutting and crimping a few wires in hope of making new money from an old cab.smarty2018-10-09 15:59:02
