Time Crisis 1
Entity
1CR
Hi All,
I'm currently resurrecting a TC1 that's been in storage for 11 years and I'm now 99% of the way there to get this thing up and running again.
Everything is now working EXCEPT I'm not able to actually hit anything on the screen.
The gun does everything it's supposed to and the screen flashes when you pull the trigger.
I've continuity tested every wire from the gun, all the way to the main PCB header.
I've tried a spare gun that I know works.
I've tried a spare gun board (the one inside the cab) that I know works.
...other than that, I'm completely stumped.
Any ideas or pointers would be appreciated.
Thanks in advance.
2,272CR
Yeah first thing to do is stick it in test mode (little toggle switch in the coin door) and try and calibrate from there. If that doesn't work separate and reseat all the boards in the pcb stack.
Entity
1CR
As it turns out, when I put the new PSU in, I set the voltage at +5v at the PSU terminals and it was only about +4.35v at the PCB end. Turned up the voltage and it now magically shoots stuff!
The monitor could still do with being a bit brighter though, too.
Thanks to everyone that replied.
Smraedis
105CR
I remember mine having a similar issue, my old supergun setup just struggled to push out the correct voltage when it was getting to the gun, but other gun games work fine with it. (sorry I've only seen the post now)
