Time Crisis,, slight graphical glitch
Flynn
69CR
Noticed a problem with what I think might be shading on my Time Crisis.
Plays fine, but edges seem to be corrupt.
I'll attached some pics, it just one edge of characters/ buildings when its most noticeable.
Easy fix, or is it a sign of something worse?
Flinnster
The Dino King
29 (100%)
2,566CR
I can't really tell what the issue is, I guess the photos are not that clear.
Vertical dark lines going down some of the textures?
Light sky area on the left of the title screen?
Black pixel blocks on the lower edges of the logo bitmap?
All would suggest some kind of graphics ram going I think.
Flinnster
The Dino King
29 (100%)
2,566CR
If it's the light edges thing, it's where the lighting from the models is being offset into the background by about 8 pixels horizontally. Sadly, video board = lots namco customs = hard to fix, from what I understand.
tb2000
3,584CR
Could be video board ram as said. Could also be a slightly iffy rom (board), but then it could also be a slightly iffy dsp board. Only way to find out which is the culprit for sure is to swap out each one for known 100% working ones.
lix
546CR
If some of the textures have vertical black lines in them then it's most likely a ROM board issue. It could be a dry solder joint on one or some of the mask rom chips, or the mask rom chips could have died as they're usually Fujitsu chips on these boards, and well, they're known for just being generally crap.
I had the same issue on a Rave Racer, a re-work on the rom board with a hot air soldering station fixed that, of which a PC / phone repair place might possibly have a go for a fee. My Time Crisis took a long time to fix, that was basically a load of dead mask roms which I had to locate and replace.
Smraedis
105CR
Here's some screen caps of the glitches on my board, it's got worse since I took these too...
