Monstermug
I have an original Taito space invaders cocktail with Toei GM-140. Fixed everything on the monitor except for one nagging issue I can't seem to get my head around.
Basically on cold start (when I say cold it's more like room temperature 20 degrees Celsius) the screen rolls horizontally, first really fast and then slows down.
It takes about 1 minute before the screen slows down to a stop and then it's stable like new.
I have already changed every single cap on it (to fix a number of other issues and not just this) and tested all the components which seems fine, although without schematics it's hard to tell if a component is within spec or not.
Now the weird thing is, when I raise the temperature by say 5 degrees and turn it on from cold. It works fine with no screen rolling. Then I tried giving it a short blast with a hairdryer before turning it on and that works too.
The problem is on the chassis. Something is heat sensitive. Grant has pointed out that it could be the three or so inductors that are on the board. But without schematics, there is no way I can find out the correct value of these inductors.
Any one with a working Toei GM-140 and LCR meter can give me an accurate reading please? and possibly the pot value of the third pot to the right when looking down on an installed chassis.
What other components can be heat sensitive like this?
