Problem Toshiba 2835DV CRT TV Vertical Collapse
2huwman
331CR
I switched this TV on this morning after a couple of years of not using it, and of course it's not working properly! It's a shame as it had a really nice picture and hadn't been used much. I'm assuming this is 'vertical collapse' (which is how I feel when my stuff breaks!).
Does anyone know if this is fixable? I can do basic soldering and can usually follow simple instructions. Any help much appreciated. Thanks!
tb2000
3,068CR
Yeah that's vertical collapse. Assuming as it's a TV and not a monitor the vertical deflection plug terminals aren't burnt/overheated, it could be as simple as a dry cap or something. Problem with later TV's like this is that just about everything is computer controlled so i'd guess there's not a standard vertical deflection chip like you'd get on an arcade monitor chassis. With that said, some of the later multisync arcade chassis that are osd types still can have a vertical deflection cihp so it might be worth looking for one just in case it has got one and checking it's not shorted and checking the surrounding circuitry.
7,135CR
Apolagies for interrupción.
Does the flyback supply
The 27v on this chassis ?
Is piggy backing these ic
With new ones to test
Hori/vert deflection ic
Applicable ?
Checking correct voltage supply to vcc first before piggy bck.
Trouble shooting similair issue with ic .
Thx
