transformer testing and repair
mathj
499CR
hi
my killer instinct cab broke down a while ago and it took me a while to find what was at fault
after much fiddling and testing voltages it turned out the transformer or power brick in the bottom of the cab was giving out some odd voltages
as far as i can tell it has 240v going in 1 end and has 2 outputs, 110v that feeds the monitor and 240v to the switcher but the voltages are not right on the output end of things
i need to do some more testing now its been removed from the cab but are these thing repairable?
it will be almost impossable to find a replacement so i was hoping it can be fixed.
has anyone ever had one repaired before?
math
4,058CR
Transformers are not really repairable things, unless you really, really knew what you were doing and wanted to rewind one (which trust me, you don't).
Don't really see it as a problem though. If it only has the two outputs, one for the monitor and one for the main PUS then really all you need is a monitor ISO as if the switcher is running off 240 then that could be sent direct. I guess to be entirely correct then you could just add two new transformers, an ISO for 110v and an ISO for 240v. And that's if you really can't find one with both those outputs. They're both standard voltages so nothing funky.
I have known a KI cab that used to give a 240v shock if you grabbed the coin door so maybe that one did indeed need the 240v to be isolated? Don't know. It shouldn't have done that anyway!
  • Like
Reactions: trm
mathj
499CR
i think its mainly for the monitor as my ki2 runs a 240v monitor from the mains supply
only interested in repairing it as i want to keep the cab as original as possable
will have to see if it is a 110/240v switchable one, maybe i could then ship one in from the states
math
