It might not be what you're after but I bought a [
SWIFT S41-20] Stereo microscope to have a play with some SMD soldering.
I didn't want to buy anything crazy expensive as it was only going to get light use but I've been really impressed with it.
The downside of it at this price point is that it only comes with fixed magnification lenses of 10x and 20x. I've only used the 10x and it's been great for stuff down to 0402. I've not found need for the 20x as yet. 10x is also great for soldering through through hole stuff as monstermug with a microscopic level of perfectness
It does make SMD stuff so much easier, it's almost like cheating!
You can buy other lenses for it. I think if I was doing a lot of through hole stuff with it (which you don't really need it for) I might buy a set of 5x lenses to make it easier to scan round a board faster.
It's got a pair of goose neck LED lights on it which you can position to get the best possible lighting and they work really well and are arguably better than a ring light:
Space was also a consideration as I don't currently have a large workbench here whilst I'm working from home and so this one was ideal as you can flip the scope up and it then has a fairly small footprint:
If you are interested there is a good review on youtube here:
[tube]0hHRV0wV34E[/tube]
I'm not normally one for buying 'cheap' but I thought I would start out with one of these and see how I got on. For what I will use it for I don't think I'm going to need to buy another.
FrancoB2020-11-06 08:13:24
