tymawrcymru
Proud UKVaC Member.
- Credits
- 50CR
Hi All,
I have a Tron machine with an optic spinner. The sensor failed and has been replaced.
Now I have a partially working spinner as follows:
If you turn the spinner clockwise, it works fine. If you turn the spinner ANTI CLOCKWISE it turns clockwise. i.e you only get a clockwise turn.
HOWEVER,
if you activate the sensor (without the spinner) say, with a piece of cardboard, with the game active, you can get the graphics to rotate both clockwise and anticlockwise.
So.... it must be the spinner disc itself right ?
BUT when I put the machine into test mode and use the user input menu and test the spinner,
I get positive and negative readouts against PL1. i.e it appears to be working?
However, IN the service manual, it shows TWO readouts for the spinner, though PL1 and PL2 though only PL1 appears on my service screen.
Should there be two readouts indicated on the service screen menu or just the one ?
If you have a TRON machine, could you have a look to see whether you have 2 readings on your
service menu?
This is doing my head in !!!
Your help, as ever, would be appreciated.
Cheers,
Gavin
HOWEVER,
service menu?
Cheers,
Gavin
