tron power supply
leslie
42CR
Hi my Tron machine has just arrived from the USA and i need remove the original battery from the power supply (before it starts to weep) and up grade , not sure what battery to use or what diode to use , please help
ZedEx48K
8-Bit
1,424CR
Wait till the sunny weekend and sports has finished!
monty
39CR
I'd remove the linear power supply and install a switcher. Order this from Arcadeshop in the US
http://www.arcadeshop.com/mcr/mcr.htm
4,058CR
Or order another of the original spec ones and mount it remotely with wires somewhere safe (coin box maybe?) Varta 3.6v I think, but check the schematics as it's over 10 years since I last did this and I can't remember off hand.
edwoodjnr
246CR
I have been reading a post on KLOV about this.
Apparently all you need to do remove the battery and replace the socketed SRAM chip at B2 with a battery backed SRAM. You can use any of these:
Dallas RAM DS1220Y
M48Z02-70PC1
M48Z02-150PC1
The KLOV post is here:
http://forums.arcade-museum.com/showthread.php?t=90255
