trouble shooting chassis
8,292CR
currently trouble shooting a nanao ms9 29u
just starting from scratch and so far all i have done is connected the power to the chassis..
just power 110v from a sega isolation transformer which i have measured with a multi meter.
making my own amp universal 15 pin wiring loom as i go.
also earthed the chassis ,,
so cant see any neck glow , and get high pitched squeal.
my question is should i get a white bright glow and neck glow with just power ac power only?
thanks for help
andyman
1,059CR
You will only get bright white glow if 'screen' is turned up on the lopt...squeal says something is working though and not all monitors show neck glow...
8,292CR
Thanks grant /andy . Ok ,, I will fit new transistor ic
And try the turning up the drive a bit...
I read that the squeal can be the ferrite core resonating
Like it’s come loose ?
But would the high pitch sound also indicate bad “hot “?
Thanks going to change the hot
And caps... too
Then will try again
