Another one from a bulk deal that wasn't working.
Jamma - tested and dead. Static coloured screen. Battery rusty as hell - obviously suicided years ago.
Snipped off the daft battery and burned 2 replacement roms that use decrypted code. Bent out pin on Kabuki, so it can use the decrypted code (I think it just behaves as a normal z80B)
Still nowt, but got a static yellow garbage screen after the first brown screen. Checked all roms. 9 and 10 didn't come up on Hamster's rom ident, so I blanked them and reburned with the right code. Still same result.
I replaced the kabuki with a z80B and got the same results, so I'm pretty sure the cpu is ok.
The only other socketed chip is a PAL, which I swapped out for a same type (but I'm presuming PALs have code on them that would need to be rewritten for the specific use?) The screen does change from the yellow.
Any other things I could try?
ps - +5v is good on chips and no obvious missing or knackered parts. There is a large piece of material stuck to the bottom of the pcb under the cpu.
