Tube vs chassis
mysticmonk
1,051CR
Im very green when it comes to monitors in general, but I have a vague question.
Tube versus chassis... What is the ratio for "problems"?
In other words, you're looking at a monitor that's a non-worker (just been told, no testing) , what are the odds is the chassis versus the tube?
5:1? 1:1?
If you had access to a load of chassis would you be feeling a lot more confident?
Will a new chassis more often than not save the day?
Bonus question: new in box lopts, a valuable thing?
Ace`
PlanB contributor #1
40 (100%)
4,040CR
Tubes rarely go bad (apart from the ones in Naomi Universals) I'd say more yokes have failed than tubes. So the majority of the time it's going to be a chassis problem.
Don't know about lopt value, depends if they're high quality or chinese made that are still available I guess.
mysticmonk
1,051CR
Good to know, I had that suspicion. About the lopts they're not Chinese jobbys, but it's not that important really.
Good to know about the naomi tubes too, thanks :)
5,332CR
It’s probably irrelevant to your question, but I think rear-projection monitors are the exception, as they’re regularly burnt-in. The 3 CRT tubes are liquid-cooled, but that isn’t enough to stop burn in of static text.
mysticmonk
1,051CR
Such a shame about the rear projection stuff. All those deluxe Sega cabinets like house dead and star wars and ocean Hunter...
Megalo systems too, but I don't know much, maybe there's a complicated fix for them. But not relevant to me right now anyway thankfully
tb2000
3,584CR
Main reason for burn in was they used high intensity brightness tubes to get a bright image, which burned in quicker especially with stationary images! That's why 99% of rear projection CRTs are fine.
