TV as display?
simplesi
64CR
Hi,
Is it possible to use a standard tv as a monitor, using a VGA to SCART? Are there any constraints? Could this be done with a 60 in 1 or through MAME?
Si
IDCHAPPY
KANFU Master
9 (100%)
1,523CR
You can have a shot of one of my superguns if you want?
Mk 5 has composite and s-vid tv outs
trm
2,877CR
If you're talking about using a TV as a PC monitor then we need details about the TV. Modern plasma/LCD all tend to support common PC frequencies, but anything which only has a SCART socket is unlikely to take even 640x480 VGA. Does the TV have a PC mode?
VGA uses a horizontal frequency of 31.5 kHz and 'normal' TV uses 15k, so a significant difference.
AeroCityMayor
Entity formerly known as alien_mame
100CR
I'm using a Radeon 7000 IIRC
No special graphics card or tweaking required - just plug it into the mobo, install the drivers and you're good to go.
TV is a Panasonic Quintrix FWIW
Cheers,
Ralph.
