Ultimate Scart Adapter
BabyDuckGames
14CR
Hi, I have recently purchased a Hyper Sports PCB and have been looking to get a 19 inch monitor but have had no success with getting a monitor. My web searching has brought me to this nifty device http://arcadeforge.net/UMSA:::15.html It basically allows you to connect your PC to a CRT tv (VGA to SCART). I just wanted to know if anyone has used it to connect an arcade PCB to a CRT tv rather than an arcade monitor and what results they got.
I have purchased one anyway but would like to know what other people's experiences have been, there's plenty of stuff on the web regarding people using it to connect a PC to a CRT tv but no reference to arcade hardware. I believe it would work, well I hope so anyway !
obcd
3,830CR
Be aware that arcade hardware uses 0V - 4V video signals with a high impedance output.
PC vga cards use 0 - 1V with a 50 ohm output.
While reducing the voltage amplitude is simple using a resistor divider, the impedance change requires an RGB video amplifier with 50 ohms output. Depending upon the output impedance of your game board, it might or might not work.
BabyDuckGames
14CR
Just checked, the device outputs 1-3V RGB, 12V for AV, 5V for sync generation Lets hope it does work, fingers crossed !
BabyDuckGames2015-10-21 11:12:53
Smraedis
105CR
I tried a similar method here for non jamma games, but wired it myself.
I couldn't get it to work right, though I have a supergun, which is the normal way to put arcade games on a standard CRT.
minwah
238CR
I think the issue could be (as obcd is saying I think) that the actual INPUT to the device might be a problem.
ie the UMSA is expecting a low level VGA input, and your game board might be outputting a higher level RGB signal.
obcd
3,830CR
Assume the output impedance is 1K and the input impedance of the UMSA is 50 ohms.
In that case, the video signals will only be 1/20 of the output video signal.
So, that gives us a maximum of 5V / 20 = 0.25V video signal at the input.
It's hard to know the output impedance without schematics. The same is valid for the input impedance of the board. Normally, it should be 50 ohms to prevent cable signal reflections.
