Universal cocktail cab help please
shrunkenmaster
162CR
I've finally got round to drilling the locks on this, so I have the long side panel open and the cash box out, but I can't see how to flip open the top. Can anyone help?
Adrian Purser
213CR
There is a small lever on the right hand side. See the pics below -
paulcan69
945CR
Ade I need help with mine
I only get 4.6v on my cab
Is it due to old psu and 200 volts vs modern day 240v
Can I change a winding on the transformer to up the voltage?
Adrian Purser
213CR
I think that these tables should work fine on 240V but I could be wrong, I haven't done much with Universal tables.
I had a similar problem with someone else's table a long time ago and it ended up being a board (or heatsink) that was mounted to the underside of the cab. I swapped it with another one I had so never really got to the bottom of what was wrong. I can't really remember much about it, it was so long ago. I think it may have been a regulator or transistor.
obcd
3,830CR
200V versus 240 should give you a higher voltage, not a lower one.
The 5V should be stabilised, which indeed is done with a regulator or power transistor.
As those convert the excessive power into heat, they are usually mounted on a heatsink.
A bad capacitor can also cause issues. You would need a scope to figure that out. If the input voltage of the regulator is to low, it can't maintain 5V at it's output as well.
paulcan69
945CR
Thanks for the info
I have tried 2 pcbs with this cab
One came with the cab so unknown
One good tested pcb but on a Jamma rig not tested for a/c
But I think it's unlikely that 2 pcbs are bad?
Possible but unlikely
Mine is a cosmic guerilla cocktail cab all original lovely little thing
Just wish it was working
I'm terrible with a/c cabs they scare me lol
I would start a thread but I think there already is one on here but it died a death no-one else could help!
I've had the cab well over 1 year now and still never played on it :(
paulcan69
945CR
I do have...
An old HM203-7?? (Maybe a 7) 20mhz Scope (Not many hours of use by me, but I'm ready to learn)
Logic Probe (With pulser)
Multimeter
ESR meter
Loads of spares, i.e caps/chips
3x eprom prog'ers Galep 4, Wellon VP 280 and a Data I/O 29a
Other transformers (maybe one that's ok for this cab...need to check)
A willingness to learn...LOL
2 Cosmic Guerilla pcb's (Both display the same fault)
I'm just crap with A/C it does freak me out...
I have a dodgy op wolf cab which has been a nightmare and killed pcb's for fun, since then I have replaced everything on the gun/sound power board...but now have to get my 2 boards re-fixed damn cab!!!
Hopefully I've got rid of the A/C issue on that cab...
Hate A/C in cabs with voltage regulators
But would love to understand this little cute universal cab, it's really tidy and I want to leave it completely standard just want it running.
Both pcb's don't boot, monitor is fine I fed it another signal from another test rig and all was good.
I just get a purple ish screen with lines, which pulses...like it's trying to boot and then resetting
The 12+ fine
The -5v fine
It's the +5v which is low at around 4.6v which I guess is too low to boot a pcb.
I'm tempted to find another transformer, wire it to a plug, make sure it feeds the correct A/C 'in' voltage for this cab's 5v rail and blam!!
Really need some help with this...
Please?
Sick of it gathering dust
Do I start a new thread?
Shall I dig out and bump the old one?
Thanks for your support so far...
I hope what I've said shines more light on my issue.
Ta
Paul
paulcan692014-09-08 10:50:17
obcd
3,830CR
4.6V is indeed very low for a pcb to boot properly. If supplies are adjustable, we even used to adjust them to 5.3V Some voltage losses in the cable made the pcb voltage 5.1 - 5.2V which worked without issues.
It would be helpfull if you had a link to the schematics of that supply. With that and some foto's, it might be possible to provide some testpoints to check.
Don't connect the game board to the supply if it's not working properly. Use another load like 2 12V 50W halogene spots in parallel. Those would still pull some amps out of the 5V supply and make it possible to "stress test" it under load.
I sure hope with transformer, you mean supply? A transformer lowers the mains voltage, but the voltage is still AC. A game board needs some DC voltages, not AC.
Maybe an old PC AT supply could give you the voltages you need. Modern PC's use ATX power supplies, bot older (486 - Pentium I) used AT. Those don't have a 3V3 output, and they don't have a pin you need to pull low to turn on the supply. Maybe the current of such won't be sufficient. You will need to check on that. You might find such an old pc on a flee market for a very cheap price.
