Picked this one up at the weekend. Hope to save it and make it into a nice little single button space invaders multi-table (and for any other vertical 2-way stick, 1 button games).
First thoughts:
- Legs won't be just a chrome job sadly. Looks like they have collapsed at the base, so will need welding
- Missing coin box (ain't they always?), and missing a lock from the side access door.
- All the lower box grilles seem to be missing?
Need to see if I can get the monitor working as it was removed to make way for a flat panel. It's a Sanwa 13CM76 chassis, and appears to be colour - it has RGB, ground and sync wires going to the neck anyway
No ISO or switcher (Need a 240-100V iso transformer for the monitor)
Tube looks almost burn-free
- Monitor bezel is missing.. looks like a teeny 13" monitor in these things?
- Control panels seem OK but some of the paintwork is scratched (might leave, or maybe paint in the scratches?)
- Player 1's fire button has a fag butt burn in the middle of it, and one of the square player start buttons is missing the innards (switch mech and bulb).
- Need to try and source wood-effect t-molding..
- Glass and clips for the top totally missing (I guess the red border on these tables was printed / painted on the glass itself?
Has anyone got a manual scan for any Universal cocktail? Might help me figure out the sizes of certain parts (plenty of bolts missing around the monitor frame and cab in general).
Stuff to do:
Get the monitor tested, see if it fires up or just burns
Get an internal 100v Jap spec ISO transformer for the monitor
- Strip the joysticks, treat the rust + respray shafts black
- Novus the balltops
- Treat the CP rust on mounting parts
- Fit new start buttons
- Figure out replacement P1 fire button
- Wire up the coin mech / reject button switch for coin1
- Get legs welded + rechromed / pow coated
- Get repro glass cut for the top
- Find unobtainium corner glass clips, or repros
- Find monitor bezel / surround (13"?)
- Try to find flat wood effect 3/4" T-molding... or failing that.. just use brown?
- Figure out what to do with grille holes in the base? Spray mesh black + mount on inside?
Flinnster2019-07-31 01:31:57
First thoughts:
Stuff to do:
