US cabinet with step down convertor
46CR
Hi all,
Maybe a stupid question but I'm looking to get a cabinet which is being imported from the States. Would plugging it in to a standard step down convertor be ok, or is there something more to consider when it comes to cabinets?
Many thanks
monty
39CR
Some cabinets (most ATARI) ones have voltage selectable plugs on the power block. Either way you'll be fine using a step stepdown transformer. I've used 500W ones without any issues.
DanP
Administrator
2,232CR
You will need to consider changing any fluorescent lighting ballasts over to ones running at 50hz, even if you're running off a step-down. If you run the US 60hz ones they will either fail quickly or at worst catch fire! Trust me it happens, we even experienced it at a ukvac meet long ago.
Dan
46CR
Dan
Ok that's good to know - didn't even consider that!
4,058CR
You also still haven't answered which cab it is.
I know of at least one that will not work properly on 50Hz even with a step-down. And I guess we are not talking pinballs because that's an entire different ball game (excuse the pun!) modern Stern pins (post 2010 or a bit before) are region locked by Hz.
