USB EPROM Programmer
panpar227
114CR
RaveN
1,325CR
I had one of these as a backup programmer.
It wasn't bad, but note the -
  • Operating Systems: WINDOWS98SE/ME / 2000 / XP.
I did eventually get it working in Win 7, but it was flakey then.
It also died after about a year.
But it's cheap and cheerful, and if you only want to burn 2732A chips onwards and you still have XP then it's not a bad buy.
Judder
1,009CR
If you can stretch (it's still < £100 at around £80) look to getting a GQ-4X True USB programmer
I replaced my LPT: Willem with one of these and it's excellent - the software is updated all the times, no glitches and supported on every laptop I have used it on :)
Even programs 2532s which I need for my Williams ROM boards and pretty much any type of EPROM I need
No GALs support, or limited IIRK, but there are others for that.
I got mine from C-U-S who are very helpful and currently sell on eBay
http://www.ebay.co.uk/itm/TRUE-USB-GQ-4X-EEPROM-FLASH-CHIP-PROGRAMMER-SUPPORTS-ALL-WILLEM-ZIF-ADAPTERS-/121002488901
Hope that helps!
Judder2014-05-15 17:11:49
Judder
1,009CR
BTW when my Willem started dying (or not writing and reading consistently) one of the main board TTL logic chips had come loose - can't remember which one - so I pressed all those in firmly on a random whim, and it worked fine every since.
Probably isn't that, but will cost you 30 seconds to try out just in case!
panpar227
114CR
I am starting to think that buying one of the cheaper writers is actually going to be a bit of a false economy in the long run.
The GQ-4X looks like a nice solution, I think that's probably going to be the one to go for.
Thanks for the nudge in the right direction
