USB Keyboard Encoder Should Work In Notepad Right?
Carlito3
115CR
On the last leg of my Trimline self build and starting to hook up controls.
I have a keyboard encoder that, I am ashamed to say, I can't remember where I bought it from. It's definitely not anything Ultimarc and looks like a xin-mo but there is no "Xin-mo" writing on PCB.
Anyway, I've hooked all the switches up as per the xin-mo pin out diagram and plugged USB cable in to pc. It tells me my USB input device software has installed correctly (I am using Windows 7). Before I tidy up all the wiring under the control panel I want to make sure I've got the switches connected up to the correct pins so I thought I could just open up notepad and test all the switches using that - press a switch and letters should be typed in to notepad - right?
It doesn't seem to be working so just wanted to make sure this is the correct way to test?
I have all the grounds daisy chained together and connected to pin 9 so it's not a grounding issue.
AndyCarlito32017-03-05 16:03:04
ZedEx48K
8-Bit
1,424CR
If it is a keyboard encoder then yes, if not have you tried opening the control panel/devices and printers and seeing it it shows up there as a game controller?
Carlito3
115CR
Ah...
I have a Xin-Mo Dual Arcade controller showing up in devices.
Guess that answers the question as to what brand it is and why it won't work in Notepad!
Cheers ZedEx48K
