Hi dude,
Welcome to becoming a board fixing pro!
This is the datasheet I'm using in case you want to open it
http://lois.ultrax.org/trmatthe/forumimages/74LS374.pdf
First decoding the datasheet.
74LS374 is a flip flop (which I never thought a very helpful explanation) also known as a latch (which makes much more sense). These chips will latch (freeze, hold, stick) their output pin to the state of the input pin when a certain condition occurs.
From the datasheet description:
3-state octal d-type edge-triggered flip-flop.
3-state: this means the outputs can be either high, low or Z. The first two are obvious but Z state aka high impedance means they can go into a don't care, don't affect the bus mode. Wouldn't worry about this atm.
octal: there are eight of them.
d-type: there are a few types of flip-flop which are controlled differently and have different uses. A d-type flip flop has a data input which is copied to the output whenever a clock pulses. This is a pretty decent explanation of the other types
http://www.dummies.com/how-to/content/digital-electronics-types-of-flipflop-circuits.html
edge-triggered: the flip flop carries the input to the output every time there is a clock level transition, so when the clock goes from low to high the output Q will be set to the state of the input D.
The truth table (sometimes called function table) for a logic chip shows what happens for each of the input states. This is key to understanding what the chip does and will be present on all datasheets.
/OC - Output Control is pin 1 and is an active low signal. It causes useful things to happen when it's low.
CK - Clock is pin 11. It synchronises all activity of the chip.
D1-D8 - arrayed over the chip, these are the data inputs.
Q1-Q8 - again arrayed over the chip, these are the latched outputs.
Line 1 of the truth table shows that when /OC is low, the clock is on a rising edge and a data input is high, the corresponding data output will also be high. So if /OC is low, D1 is high, CK is pulsing then Q1 will be high.
Line 2 shows that if /OC, CK are the same as before but a data input is low, the corresponding data output will also be low. So /OC low, D1 low, CK pulsing, Q1 will be low.
Line 3 shows if /OC is low, CK is low and
not pulsing then the data input is irrelevant, the output will be whatever it was before the clock stopped.
Line 4 shows if /OC is high, then the CK and data input are irrelevant and output will be Z state which means it's not outputting anything and isn't affecting anything it's wired to. Kind of in sleep mode.
To recap the key points, /OC is the master enable signal and is active low as indicated by the / symbol. If it's not low, the '374 isn't doing jack. When /OC is low and you have a working clock, the input data will be copied to the output data.
This chip doesn't sound like it's very useful - input copied to output and that's it? But often the CK signal will be controlled by another chip and won't be a regular clock such as you'd find feeding a CPU. So you could use this by feeding the input states you want, pulse CK and whilst CK doesn't pulse, the Q1-8 outputs will be latching the data you setup, which gives opportunity to do something else on the input side. I suspect this is what it's used for in the video part of Joust.
Next post how to logic probe this, but first I'm gonna find schems.
