Monstermug
I wouldn't go less than 0.8. Make sure you have fuses in line on the power line connectors yeah?
Monstermug said:maybe tidy up the high voltage cables to avoid interferance? also dont forget the fuse inline on the power . u can potentially melt the trace off the deflection board if something goes wrong.
Monstermug said:Yes i learnt the hard way. I used slow blow in line. Forgot how many amps though. Did u turn it on yet? Dont forget that high voltage cap on the crt neck too otherwise u get a shaky image iirc.
lix said:The pincushion correction circuit on Tempest was needed for the WG6100 tubes, either it's not working fully on your PCB or it needs ramping up a bit to cope with your tube and yoke. I don't think there's a manual adjustment for it so it'll require changing resistor values around the MC1495L chips in the correction circuit. That's just a guess though.
I have the same XY kit and get a reasonable picture on my original Star Wars board which has no pincushion correction but I didn't get the coil impedance matching right between the two coils so I'm getting a bit of a convergence issue from top to bottom of the screen. I basically need to redo my yoke winding as I messed up and cut the wire too short after not bunching it up properly.
For the wobble issue, I found that it was magnetic interference from the flyback transformer affecting the yoke, so I had to shield it by putting it in a metal cage. I ended up using the case from a dead PC power supply which does a great job, it's not 100% cured as I've mounted it all in a Hantarex 19" frame so there isn't much room to space the flyback far away from the yoke but it'll do.
