Vectrex cap kit
bonehead
I'll get pix tonight
50 (100%)
1,729CR
I have picke up a vectrex sold as working but on arrival I just get a white dot and the of erratic line across the screen. I can hear game sounds. Thinking I might try a cap kit as I have tried reseating chips and plugs.
Anyone know if cap kits are available or would I have to make one up? Even better does anyone fix these?
The seller does to want to know that it arrived dead on arrival so would like to fix it as I paid reasonable money for it.
Thanks,
Steve
DanP
Administrator
2,232CR
I have a list of the caps needed at home somewhere if you want to make up your own cap kit. From the symptoms I'd doubt that it would fix it though...
Dan
cparsonsuk
205CR
On the basis of checking the basics.... a white dot with lines all over can just mean the brightness is up high... when like that you can see all the movements of the beam inbetween drawing that are usually hidden.
So just in case you haven't tried/found it... try adjusting the brightness control on the back of the unit.
cNp
bonehead
50 (100%)
1,729CR
I have tried the brightness dial but it doesn't make it any better other than making the dot brighter.
I will check out the you tube links.
Purity
The Oracle
2,999CR
I also picked up a Vectrex las weekend, fairly cheap. It powers up as
normal but has a very weird fault where Mine Storm resets back to the
main title screen. Anyone seen this issue before?
Not tried it with another cartridge yet, so don't know if it is just the internal game
bonehead
50 (100%)
1,729CR
I have tried ref lowing the header pins and cleaning but no progress. Cleaned the legs on the 2 socketed chips but got no further. I will try and find a schematics file on it.
joe34
448CR
Steve: as some others have said already, i would be surprised it if was a cap problem. visually inspect the electrolytic caps though, for bulging or corrosion, and if they look ok, i wouldnt worry about the caps just yet
Purity: I think i read in the past that could indicate a problem with ram
if you havn't checked out these forums yet guys i recommend spending an hour or so reading through the past threads as you may encounter people with the same issues you have (especially the white dot problem which is a common issue)
http://atariage.com/forums/forum/182-vectrex/
http://vectorgaming.proboards.com/board/20
Purity
The Oracle
2,999CR
That's Joe, my initial thoughts were issues with ram/rom, so I will check those out.
I'll need to see if I can find a dump of the vectrex rom inside the unit
Purity
The Oracle
2,999CR
I manged to get this working.
Removed both 2114 rams and they were ok. Put new sockets in just in case they go wrong in future.
The problem was with the rom. It's a D2763-4, which I managed to read as a 2764. I checked it against the bios file "exec rom intl 284001-1", and it had a bit of bad data. I took this data and tried it in Mame, and the game crashed as in the video, whcih confirmed the fault.
Wrote the correct bios back to a 2764 and I have a working Vectrex.
Not bad for £50
