I pulled my Vectrex out the the other day only to find it displayed white dot just NE of the centre of the screen.
I understand this is a common issue, so I followed a few guides online and did a few bit and pieces like reflowing the header pins between the two boards. No idea if its coincidence, but I moved one of the pots on the lower board and the screen appeared. Gave that a clean with switch cleaner and it seemed OK until I switched it off a couple of hours later.
Switched on again today and had the same problem. Switched off and on a couple of times and it's come back and is now playing fine.
On that basis I'm assuming its not a serious problem as it appears to be intermittent - can anyone give me any pointers as to what it might be?
