Hi everyone,
After replacing all the electrolytic capacitors and the five DAC capacitors in my Vectrex, I’m still not happy with the display.
All voltages are stable and within the specifications in the service manual. I’ve carried out all the adjustments I could, including setting the NE555 timing to 10 ms / 40 ms using an oscilloscope.
However, the test grid still jitters quite badly. Every now and then, the whole image briefly expands, almost as if it’s “zooming in.” Unfortunately, this doesn’t show up in the video. Some of the text also looks distorted, which you can see in the video.
I suspect that something other than the capacitors may be causing these problems, but I’m running out of ideas about where to look next.
Has anyone experienced similar symptoms, or could you suggest what I should check next?
Thanks in advance!
