Vendetta PCB no boot
urbanledge
95CR
I picked up a few non working PCBs and would like some advice please!
First up is Vandetta!
Here she is
Looks original to me (Im no expert tho)
It has a few repairs,Looks like these two chips have been off.
The sony and the motorolla below it.
Looks good on the solder side (in my opinion!)
And a tiny wire replacing a trace.
So the game boots to the self test and becomes stuck in a loop.
This is what I get.
EEP rom test OK recommend set OK
So 17C says DA2B
and 5F says 0S1E
What do you reckon?
Is there life in this old girl?
Sorry for the long post!Manual here if needed
http://pdf.textfiles.com/manuals/ARCADE/S-Z/Vendetta%20[Instructions]%20[English].pdf
urbanledge2014-01-30 22:22:35
PaulSwan
ZZZ
1,118CR
The test input is stuck or the test DIP switch is on (if there is either of those on this game). Sometimes, stuck coin or other inputs can have the same effect on some games.
Paul.
sukhbir
46 (100%)
1,734CR
hi,as a guess i would say the 2k sram chip at location 7f on the pcb(2nd photo from top) is bad,to be sure i would take the game out of test mode and check the data and address lines on the chip at 7f using a scope.hope this helps.
sukhbir
46 (100%)
1,734CR
test mode is the give away,from experiance the symptom on your board does look like a duff sram chip.you can also try to piggy bank that chip with a good one and see if it works,be careful not to short out the pins.
VectorGlow
34 (100%)
900CR
POST (Power On Self Test) is failing because the RAM at location 7F isn't passing the test. This doesn't mean for certain that the RAM is bad, there could be a problem elsewhere in the circuit.
This RAM is part of the colour circuit, and the fault related to it is why the POST text is displayed in blue (it should be white) and also why the word BAD isn't showing up besides 7F on the POST (the colour palette is messed up because of the RAM related failure). In my experience, colour problems on Konami boards of this era are fairly common (I've repaired a lot of them
The cause of the fault could well be the RAM, or it may be a broken (or shorted) track or a fault elsewhere in the circuit, which is why the address and data lines need to be looked at. There's also a chance that the custom surface mounted chip (053251) is at fault, although I doubt it in this case as that should affect both of the colour RAMs (at 8F and 7F).
In short, you need to use a logic probe (or better still an oscilloscope) to check the address and data lines, also the Write pin (pin 21) on the RAM at 7F. If you have a multimeter with a continuity test it would also be worth checking for continuity on the tracks to and from 7F. Use the schematics to see where all the connections are. Do this with the power off.
Let us know how it goes.
VectorGlow2014-01-31 10:46:06
VectorGlow
34 (100%)
900CR
Not necessarily, but if this is your first board repair then it's not one of the easiest boards to learn on. If you want to learn it's best to start off with an earlier game that is well documented, such as Galaxian or Pac-Man.
