Verifying ROMs from PCB
sapporo46
70CR
I have a Double Dragon II board that plays fine but is exhibiting some graphics corruption (tiny lines on title screen and down the vertical edges of some sprites), so I pulled all the ROMs and went to verify them against MAME/Winromident. The output from MAME confused me...
Identifying C:UsersSonyDesktopROM DumpsBoard PullsDouble Dragon II Bootleg....
A-1.BIN = 26a8-0.bin ddragon2u Double Dragon II - The Revenge (US)
A-10.BIN NO MATCH
A-11.BIN NO MATCH
A-2.BIN = 26ae-0.bin ddragon2 Double Dragon II - The Revenge (World)
= 26ae-0.bin ddragon2j Double Dragon II - The Revenge (Japan)
= 26ae-0.bin ddragon2u Double Dragon II - The Revenge (US)
A-3.BIN NO MATCH
A-4.BIN NO MATCH
A-5.BIN NO MATCH
A-6.BIN NO MATCH
A-7.BIN NO MATCH
A-8.BIN NO MATCH
A-9.BIN = scxgm10a.bin sc2scshxgman Super Cash X (Concept) (Gamesman Hardware)
B-12.BIN NO MATCH
B-13.BIN NO MATCH
B-14.BIN NO MATCH
B-15.BIN NO MATCH
B-16.BIN NO MATCH
B-17.BIN NO MATCH
B-18.BIN NO MATCH
B-19.BIN NO MATCH
B-20.BIN NO MATCH
B-21.BIN NO MATCH
B-22.BIN NO MATCH
B-23.BIN NO MATCH
B-24.BIN NO MATCH
B-25.BIN NO MATCH
B-26.BIN NO MATCH
B-27.BIN NO MATCH
So only 2 out of 27 ROMs could be identified?? And as for A-9...
The game plays OK so what is most likely here?
[list type=decimal][*]I've dumped the ROMs incorrectly (don't see how?)[*]The data in all but two of them has corrupted enough to be unidentifiable[*]I have an unknown board (unlikely)[*]Something else[/list type=decimal]
Also, how can I replace them if I wanted to? On one PCB layer the ICs are labelled as the "A" files above, on the other they just have the number (see image). Without a schematic/layout, how would I know what ROM goes where? The PCB has IC numbers by the sockets but don't know how that will help me here.
silverfox0786
Beware the Hillman
47 (100%)
2,699CR
I would be more inclined to think you didn't dump them properly
try dumping them again and try again
there is also the possibility of the roms being only 1 bit different due to bit rot which means the game will play but with glitches and wont verify on MAME
for that a reburn should fix it
porchy
994CR
ROMs look like those from a bootleg board. What I usually find is they use smaller eproms and split the original data up or on some occasions they use double sized eproms and the data is concatenated.
Judder
1,009CR
The Romident database is quite old and probably out of date versus the bootleg board you have
Have a read of the Mame driver source instead - around line 1513 should be interesting
https://github.com/mamedev/mame/blob/master/src/mame/drivers/ddragon.c
This has all the CRC checksums for the different bootleg versions of Double Dragon 2 which you can create for your ROM dumps using various tools
One of which is RomCmp which used to be / might still be in MAME
http://www.logiqx.com/DatFAQs/ROMQuestions.php
@guddler - the hint is in the file name above about being a Bootleg
sapporo46
70CR
Figured it was a bootleg but didn't get why MAME doesn't list a "DD2 bootleg". Looking at the MAME src I understand more now (i.e. the fact that the driver supports DD 1 & 2).
Thanks all
