Vertical collaps wei ya 3129d
8,292CR
I have this chassis
Vertical collaps
Everything Ells working,,
So I was going to change both
Vertical ic and horizontal ic at same time,
But when I went to unplug I have noticed Burn on connection And the components leg below the burned connection is unsolder or the pad is off the pcb
If that makes sense,
So I thought better to ask after I will reflow this components leg that’s come unstuck
And isolated the two pin sockets I the burn area,
I will replace ic and power up?
Or my other advice like why is this burned ?
Also red yoke wire was very brittle at the socket so much
It snapped in my hand, so has this yoke wire been extremely hot?
Thanks for any help
8,292CR
I know its 5 watts and 56 ohms , but I don't know what kind of componanat it is . is this a resister?
could it be this resister that has burned out and shorted the two wires above or is it the other way round?
and could this be why I have vertical collapse?
I guess I will replace the component make the above connection safe so wires not touching
and try then before changing the vertical ic
