Vertical Collapse??
Martinmorv
5CR
I turned on my arcade monitor (Hantarex Polo 20”) this evening. Sound was working fine, but I just get one very bright line across the middle of the screen.
Is this vertical collapse?
I’m a bit gutted about this. Is the monitor repairable from this state?
Thanks in advance.
Martin
Martinmorv
5CR
Hi, the remote board appears to be connected fine, so I think I have a fault. What steps should I take next? I’ve got some limited skills modding and recapping consoles but i’ve never tinkered with a monitor before.
I know I have to discharge it first, which fills me with dread.
Martinmorv
5CR
My soldering is mediocre to average I would say! I’ll definitely have a go. Is there a guide I can follow somewhere?
TDA1675 is a deflection circuit chip I can buy on eBay for a couple of quid from what I can see.
Which resistor needs swapping out?
Martinmorv
5CR
gunblade said:
polo 20 do hold a charge unlike polo 25 or polo 28
Sorry, I’m new at this. I read this as the Polo 20 does hold charge. Please be nice, I’m learning here!
So I can remove the chasis to send for repair without discharging?
gunblade
9,140CR
no, the polo 20 will need to be discharged- its easy to do and even if you do get a bit of ht it won't really hurt
do an internet search on monitor discharge, you do not need a ht discharge probe, you can use a screwdriver with a wire attached to it
Lurch666
4,519CR
I did my first monitor discharge earlier this year on the monitor in the jamma cab I got off ebay.
A big screwdriver with a thick cable connected to ground,touched it under the anode cap.
Got a spark,waited 5 min and repeat until no spark.
I survived to tell the tale.
Martinmorv
5CR
Hi, I’ve braved up and discharged the monitor. I now want to get the board disconnected. What holds it to the tray? I guess it’s screwed down but I don’t want to remove a load of screws unnecessarily.
