Very much a beginner question
Adpolice
10CR
Hi all,
Firstly I have no problem with the restoring of damage, cleaning, repairing artwork or the mechanical side of restoring an arcade. However I have never touched the electronics side, the reason for me taking on the Sega Rally 2 restoration is to challenge myself and learn new skills. So with this in mind I want to ask for some advice:
1) What are the base skills to learn to fix the simple stuff e.g. soldering to replace caps or testing if a board / connection is good? Also any YouTube or guides that I can learn from?
2) Is there a guide out there on creating a Jamma supergun? I feel if I could make one myself and understand the pieces this might give me an understanding on how arcades generally function.
3) Are there any good guides on how arcades work and the basic components of an arcade? If I know this I can at least start to understand how to test the health of a system piece by piece then choose what I can learn vs. what I need to seek professional help with.
Basically what do I need to know first and how do I learn it, any help will be appreciated
One last question:
4) Are there any people on here who do testing and fixing of electronics that take on jobs (I don't need one now but it could be a resource I need to tap in the future)
Thanks and remember you are all very groovy
- Chris
Lurch666
21 (100%)
4,518CR
A good start would me to make a jamma test rig.
Start with a jamma connector and wire it up to a joystick,buttons scart and a PSU.
It will be a good way to start to learn soldering and find out info about how to make it.
A big part of fixing boards is searching the net for info about a particular pcb.
Also bare in mind that a multi meter plus a logic probe or better and oscilloscope is pretty much a must.
Adpolice
10CR
That's great advice, any recommendations for the multimeter/logic probe / and oscilloscope that balance economy with quality?
Thanks again btw
- Chris
Flinnster
The Dino King
29 (100%)
2,566CR
You can get quite a fair way with just a multimeter and a soldering iron. The rest can come later - people can help you or you can send boards off for repair. Very few newcomers rush out immediately to get logic probes and oscilliscopes!
big10p
Coins detected in pocket!
6,093CR
I agree. Board fixing is a whole separate art, and I'd advise you get to grips with the basics first (I still know VERY little about board repair). Defo get a multimeter and soldering iron, first.
