Very technical inductance question
46CR
Medium Res WG4915
I have this monitor which i am doing a cap kit on. I noticed that there was a loose nut and broken long bolt wobbling about on the top of the flyback. after investigating i discovered that its purpose is to hold the two halves of the ferrite core of the flyback together, I decided to make one and after some head scratching and a few goes i managed to make one that fitted nicely and i even annealed the new threads to keep them from stripping. Suddenly it dawned on me that the original broken clamp is semi ferrious as i tried it with a powerful magnet and the new one i made is just mild steel and is definitely much more ferrous. The magnet sticks to if FAST with a click. From past experiences i learnt that i cant use a ferrous object when adjusting a width coil as the inductance causes it to get hot very quickly and potentially damage the components feeding the coil. This metal bracket i made might have the same effect as using a ferrous object on a width coil, what do you boffins think? I mean it passes right through the middle of the flyback. I dont want my monitor going up in smoke. Alternative would be to make the clamp from brass or copper.
