Hi, when you say loose do you mean the crimps come out when you pull on the wire ? Could you post a pic of the crimps out of the housing ? You see when you use a crimp removal tool all it does is firstly bend the springy bit of metal that holds it firmly in the housing back into the body of the crimp so that it's no longer anchored in position so to speak. Secondly the tool will then have a mechanism to then push the crimp out.
When you are not using a tool, like in my first pics, all you are achieving by inserting the rigid wire/component leg is bending the crimp retainer/springy bit of metal back into the crimp body,there is no push mechanism so at this point you would need to gently pull on the wire to remove it, certainly not try and push it out. Once it's out it should not be damaged but that retainer/springy bit of metal will probably no longer be poking out as far as it should so you will need to bend it a little away from the crimp body before you re-insert it into the housing. This crimp will be able to be put back in 2 ways around, the retainer/springy piece of metal must be on the same side as where you put the rigid wire in to remove it. Otherwise it will have nothing to retain to,allowing it to move up and down in the housing the same as if you didn't bend the retainer/bendy piece of metal after removal.
I've only ever bought a removal tool for the round crimps as they have 2 retainers/springy bits of metal and unless you get lucky and find a rigid enough right diameter straw then it's difficult, even if you did you would still need to gently pull on the wire to remove it,if at this point it didn't move it would mean that the retainers are still in some way gripping the housings body so you adjust/try again.
I've had another try myself and found the perfect thing for releasing the retainer on these connectors, it goes in just far enough to to allow you to release the retainer without damaging the crimp, it is in fact perfect for the job.
it's a strip of small molex header.
note the way I've bent the retainer outwards
also hopefully you can see which way around the crimp has to be when re-inserting it into the housing.
When I first saw the post I managed to dig up a few of these cables to do the first pics I posted,if yours are knackered I've got 2 in the for sale section but I'm hoping your crimps are either the wrong way round or you haven't bent the retainer back out away from the crimp body.bones2021-07-15 15:42:16
