Virtua Fighter problems
Kenth333
114CR
I bought this Sega Model 1 Virtua Fighter over the weekend. I've cleaned it up, connected some loose cables and put in a new power supply and it's now running.
It still has a pricture problem and has no sound.
I'll have to go through all the connections for the sound but was hoping somebody might know what I could do about the picture. It's still a little washed out and has retrace lines.
I've tried adjusting h.hold, v.hold, focus and brightness. I checked repairfaq.org but didn't dare try the other adjustments yet. I haven't yet checked the voltage. The monitor is a Nanao MS8-26. Should I do my first cap kit?
Grateful for any help on this.
Here are some pics of the cab
Fun thing I noticed was I'm 100% sure I played this exact cab when I was a kid. Even had a high score initialed KEN, but I think that's a default.Kenth3332014-01-27 09:48:58
Kenth333
114CR
JESSYBR said:
hi looks like someone turned the high voltage transformer
maybe you can try the control pcb for the monitor first its in need of finetuning
gr robert
Something in this section? Couldn't find anything with a quick goole.
Kenth3332014-01-27 10:03:54
Kenth333
114CR
After a more thorough google I found it's a pot for adjusting for the voltage to the tube (?). I'll have a look for it when I get home. Thanks.
Kenth333
114CR
Haven't played this in at least 10 years and still now remembered most of the grabs.
The problem with the screen was the HV (screen) adjustment like jessybr thought it would be. The problem with the sounds was a bad connection on the sound board.
Urgentemente
104CR
Looks much better :).
Used to play this in Liverpool , almost always used Kage , wasn't very good at it,but liked it.
Quite enjoyed Fighting Vipers too when they got it in Aladdins Palace for a while.
Kenth333
114CR
Couple more questions about this vf. Are the vertical lines in the top of the screen a cap problem? I read it's something to do with bad filtering.
Also, do you usually dare adjust the convergence or is it even at all risky to do? I read somewhere it's REALLY hard to get it right and you run the risk of making it worse. I assume the halo to the side of the eyebrow and the off colors on the letters come from bad convergence.
pics
Edited for less typos.Kenth3332014-01-30 10:46:19
