Volume Control in JAMMA cab
sapporo46
70CR
Hi all
Got a simple JAMMA cab setup so mono sound going to two speakers - would something like this be a solution to control the volume whilst actually playing on the cab?
r-type
633CR
They're already amped from the boards and are normally controlled from the pcb. I'm guessing you're after something that you can add in and reach from the coin door?
8,309CR
Surly you can get one with left and right terminal input
Rather than headphone jack?
Although you could use a headphone jack with screw terminals on it I suppose
But I’m sure there are amps with screw terminals for left and right input.
sapporo46
70CR
Yeah basically what r-type said, I know the sound is already amplified - just want to be able to control the volume from the front.
I'll have a look for that thread that was mentioned
strykr
1,351CR
If you can't find it Sapporo it was quite easy to do, there is a schematic in that link as well. i placed mine in a project box and mounted it behind the coin door. It works.
