Vs. Super Mario Bros
paulcan69
946CR
I seem to have lost my green colour from my Vs. Super Mario Bros. PCB
It's plugged into a monitor inverter and sound amp (the official Nintendo one)
and hooked up to a jamma so I can play it on any jamma cab.
I know it's not the roms as I have a spare set and a spare board, but the spare board only boots to garbage, but even if I swap all chips over it's still the same.
Even if I use the bad board on the monitor inverter, that has green so I know it's not the inverter/jamma adaptor it's the working board at fault.
These things have 3 pots for red, green and blue on the monitor inverter, and on the pcb and again on the pcb (cut off?) So 9 pots for colour.
It doesn't matter how much I play with these still no green.
Sometimes when you first boot the pcb up it has green for about 10-15 seconds and the pots do adjust it, but then it fades out, sometimes the green colour pulses on/off for a while then all green disappears.
I even tried freeze it spray to see if that made a difference, at one point I thought it did but I cannot get a good pattern.
What's the chance of one of the green pots (or cut off pot) being faulty?
Is it worth desoldering one from the faulty board and trying it or is there something else I can try.
(I haven't got a scope yet, and need to make a video probe, need your help with all this soon!)
Ta
G
Guests
Guest
could be a colour prom on its way out, ive never worked on a VS pcb thou, so i could be talking rubbish, do any of the chips get red hot?
940CR
Did you get any further with this one, is it plugged directly into a Nintendo cab? or does it have a Jamma Adapter?
I have a Vs S.M with the craziest looking jamma adapter with a soundboard attached to it. But the colours are very pink! have no idea if its the board or the adapter causing it.
paulcan69
946CR
Yeah I have two of those crazy adaptors, that is what I'm using, my fault is def the main board, Tim helped me prove that by back feeding the colours by switching red with green.
Yeah mine has lost green and got a very red/pink picture also, sounds like this is common and yes I still need to fix it, maybe my new video probe (WIP) shall help.
I do have a spare faulty board with good colours (boots to garb) which hopefully will have the part I need to fix it on it.
So yeah we need to stick together bud and find the cause of these red boards!!
paulcan692011-01-10 19:47:19
940CR
Here are some pics of the pcb its adapter and screenshots, I think all the colours are there, just very pink!
trm
2,877CR
You've definitely got red, green and blue so I'd say it's just a matter of adjusting the pots on the video adaptor (ISTR that there are adjustments on there).
Personally, I'd mark the current position of the pots and then adjust them one at a time (with the power on and monitor connected). I'd try taking the red down a bit first.
Also, it might help to hold a sheet of plain white paper against the monitor when you're taking the photos so we can see if there is any colour imbalance inherent in the camera, but to me it looks like red is being overdriven quite a lot.
cheers
tim
paulcan69
946CR
Yeah what Tim said, mines well red as I lose green on mine.
As Tim said I think the pots will cure that, beware you will have a nightmare getting it right, adjust as little as possible, 3 of them don't seem to do anything out of the 9 pots, go for the ones on the adaptor first.
paulcan69
946CR
Mine's all packed away at the mo in the garage, you ok to do it Bensonrad? If not I shall dig it out for the cause?
Let me know!!
trm
2,877CR
It's not super-crit but I'd like to have a look at the PCB layout and tracks to get an idea of what it's doing and how; it might help me give better advice on tweaking the outputs. Am guessing there is a bias adjust but I'm not sure what the other 6 pots do - maybe cutoff and something else?
940CR
Cheers folks, Will do (take pic), but will be at the weekend or possibly 2moro nite, as its packed up at the mo. God I didn't even notice those pots on the adapter pcb!
paulcan69
946CR
Exactly that Tim, Main RGB is on the adapter, the 3 closest pots to the edge connectors seem to be cut off's, and the other 3 don't seem to do shi*t?? (I think the last 6 pots are that way around anyway)
I am gagging to fix my one, I'm sure Bensonrad's will just be adjustment of the red channel down a bit and he will be fine.
Mike at Mike's arcade (usa) does a brand new Vs. to Jamma setup the same as these but machine made and brand new components, (with sound amp all built in) I bet it's much better than these ageing Nintendo components, but very expensive, which is understandable, imagine how much it cost to have them done.
Don't know about you lot but I find older Nintendo stuff sh*t as it gets older, just seems to let go before other stuff.
Even before my first Vs. Super Mario pcb went down I was always slightly having to mess with the pots to get the colour right almost after everytime I touched the board.
Really this is what you get for not using a real Nintendo monitor for these boards, it's a bodge/fix/work around, why else would you need 9 pots to adjust the colours?
Mine I fear is a faulty component as I have tried two adaptors and it's the same with both, + Tim and I managed to prove it was the board by back feeding green down another channel.
As I say I have the working component on another "spare" faulty board so I know I can fix it by a simple swap (once I know what to change)
The green channel is fine on the bad board I can see that even though it only boots to garb.
Good luck b-rad, once I have a video probe working i'll be all over this and Wonderboy in Monsterland.
(Both are top of my fixing/learning list)
Ta.
trm
2,877CR
From memory those two ICs with the heatsinks are MCU (mini CPUs that also have IO lines) and are probably interchangeable between Ninty boards. Or somebody realised the heatsinks had broken off so pulled them from some crappy games and stuck them on SMB.
I'll have a look at the video amp later on but I'm not seeing the 9 pots mentioned elsewhere??? Looks to me like a volume pot and then three pots (RGB) along with transistors which are biased by the pots to control the output levels. I'd mark the existing positions and then adjust one at a time so you can ID which channel which pot corresponds to. Unless it's marked and I just can't see it, or you fancy following the wiring back?
cheers
tim
4,058CR
Three of the pots are on the adapter PCB, the other six are on the main PCB.
The IC's are MCU's and I think they're shared between games.
I've not dug my Vs boards out for a few years as I don't like them but I'm 99.99% sure that the 6 pots on the PCB are R/G/B drive and R/G/B cut off, just like on a monitor. VR1 & VR3 are red. Though that should be obvious from the fact that the knobs are red
The three knobs on the adapter are there because the board outputs inverted video so the adapter inverts the video for use on a standard monitor. Adjustment can be made there too.
Start with the pots on the PCB though...
[EDIT] Sorry, looks like Paul's already said virtually all of this!
guddler2011-01-13 23:34:58
