Walls and insulation.
Mr20to5
1,366CR
Hi guys.
Whilst everyone is talking about floors I thought I would talk about walls.
My garage is integrated and therefore (hopefully well insulated) and also has a room above. But it is just bare ugly concrete blocks which I want to plaster board over.
So whilst I am at it was just going to sandwich those big 4x8 sheets of polystyrene in for a bit of warmth as they are cheap as chips anyway.
I was hoping to just tape the joints and paint the board after that so what are my options for securing the insulation and plasterboard sheets?
Thanks.
PS at least I know to use carpet tiles on the floor
Shinydaz
814CR
I built a stud wall a couple of inches off the outer wall and then stapled superquilt to that, then put roof battens over the superquilt, then drylined it with tapered plasterboard and filled in the joins.
Mr20to5
1,366CR
I think this is over the top for my needs as the garage os already well insulated. Mine is more cosmetic and I dont want to lose the space by batoning etc.
I could dot and dab the plaster board but the insulation too, wouldn't work would it?
Shinydaz
814CR
You can buy plasterboard with insulation stuck to the back of it, but it not that cheap. Does your outer wall of the garage have a cavity? If so, it should be insulated already?
Mr20to5
1,366CR
Aye that plasterboard with the stuff on is 60 a sheet. Normal plasterboard is 5 and the insulation another 5.
As ive said already the garage is fully insulated but just wanted to add a bit more whilst putting up plasterboard.
Does this make sense?
SUPERSPRINT
1,035CR
Make sure you have an air gap between the inner and outer walls other wise you'll likely get mouldy/damp interior walls, if you've already got double skin cavity walls then you can indeed stick it straight on. SUPERSPRINT2017-05-11 19:15:27
Shinydaz
814CR
Yes but I can't see how your going to attach the insulation to the wall and the plasterboard to the insulation. The only way to do it is the screw some wooden battens directly to the wall then fill in the gaps with insulation and then screw the plasterboard to the battens. But like what was said, only do this if it's a doubled skin wall or you'll get damp problems.Shinydaz2017-05-11 19:19:28
Mr20to5
1,366CR
Aye so I already have double skinned cavity walls that are insulated correctly. Its a new house relatively speaking.
But surely I can't (as said by myself originally and now shiny daz) glue everything ? Or can I?
Sorry if i didnt make this clear.
Shinydaz
814CR
I'd just dot and dab some 12.5mm tapered plasterboard directly to the wall. As the wall is already insulated, your just going to make the job harder than it needs to be.
Mr20to5
1,366CR
John Bennett said:
A bit out there, if they're not required to be breathable, you could paint the breeze blocks something more interesting than grey or white ...
http://www.beyondthescreendoor.com/2011/07/how-to-paint-a-concrete-wall-to-look-like-stone.html
No extra insulation that way, but is the garage door not a massive heat sink?
I could paint, yes but they are cool/cold to touch so just wanted to cover them with plaster board and just though while doing so could sticknsome polystyrene board up to.
I'm replacing the garage door with a fully insulated motorised sectional door which has thermal struts on the sides too.
Then carpet tiles going down.
Should be cosy and toasty with a little heating.
