Hi Guys (those with far more experience than I),
I've just taken the plunge and bought an original Bubble Bobble from Phil (Jodo) having only had a stop-gap bootleg for a short time and now the arcade gods have punished me for being greedy...
I will (later) be checking the BB to Jamma wiring harness in case a dry-joint is causing a grounding issue or voltage spikes (but it exhibits the problem on two cabinets - which kind of rules out the cab wiring harness).
I'm told these boards are fussy when it comes to grounding, but I don't think the problem is related to signal/wiring between the board and the monitor as a good deal of the display is fine.
I'm having some intermittent graphics issues with the board, where it looks like it's having trouble loading certain elements.
The issue seems to be with dynamic text (high scores, level accomplishment, credits, etc. and moving graphic elements - may be sprites, don't know if this is how this particular board creates the characters)...
It'll be fine one minute (in fact it was fine for the first couple of hours of testing) but now this problem comes and goes.
It'll crop up during a game (sometimes straight away when the cab is switched on). It'll then randomly come & go.
The issue seems to be every alternate line (but not on the level frames - just the moving characters and the text) is either missing, or horizontally offset by about an inch.
I've attached some photos of it behaving itself, then photos showing the issue.
The nature of the fault looks like it could either be a failing component either in the video circuit, the processor or the ROM where it loads the data from; or it's a lose connection somewhere (where it'll be there for a minute or two, then you get this horizontal shift effect - which a couple of the photos show, then the display will be perfect for a few seconds, then go back to either missing every alternate line, or showing the horizontal offset effect).
The power supply is giving exactly 5vdc to the board. All 12vdc, -5vdc and ground connections are present and it does it on two different cabs (both work fine with other boards - which eliminates something in the Jamma loom).
I just don't really know where to start and I'm reluctant to start removing and reseating all ICs without checking if I'm even looking in the right place.
Photos showing the board without problems;
The display is nice & clean and apart from a small convergence problem (on the monitor) it's a nice sharp image (although "BASIC SKILL" is probably about right for the way I play this game
Photo showing a "clean" display but with every alternate line (in sprites, etc. - it does the same with some text, too - e.g. on the welcome screen) missing;
Photos showing a "dirty" display with every alternate line appearing to be there, but offset horizontally;
Any ideas where to start before I give up trying to solve it myself and send it off to one of the repair gurus?
