Weird Degauss Issue
tb lilley
5 Star
1,686CR
I have a degauss issue that I'm struggling to resolve. Monitor came to me last week. It's a WG D7700. It was bought BNIB back in 2006 and since then until recently had been in service in a RFM pinball. The guy I bought it from was an honest guy and made it clear that whenever he'd moved the pinball the colours on the screen messed up, particularly on the bottom. So no complaints and I fully expected a degauss issue.
Anyway, here is the monitor freshly installed in Missile Command:
Sure enough, the bottom third of the monitor is well off. Should be uniform yellow across the bottom, and 'Defend Cities' text should be blue to match 'High Scores' text. Fixing the degauss issue should be a fairly trivial issue - just replace the thermistor (there's really nothing much else in the degauss circuit) and I expect all will be well.
However, rather than order the required part I threw together a ghetto degausser of my own from a long departed WG4600:
Used that to degauss screen and I got this:
Which is much improved and looks pretty much perfect. But it's not. If you look closely the colour blue on Cities is very slightly off. And there is clear evidence of further degauss issues once the game gets to the waves with the pastel colour backgrounds. It's not a huge issue, but it's irritating and needs sorting.
I thought that perhaps my ghetto degauss tool and my application of it might be at fault. So I tried an alternative. The cab next to Missile Command sports a K7000. So I jumped the degauss output from that straight into the degauss coil on the D7700. No change.
So .... where I'm at now is that I reckon I've degaussed the monitor successfully, but a problem remains. The most obvious potential cause is magnetic interference from somewhere. But that's not making sense. Prior to fitting the D7700 the MC had a nice Hantarex 900E. No issues. Cab is in same spot it was when it had the Hantarex and nothing else in the external environment has changed.
I'm scratching my head on this one ..... One thought occurs - as the monitor came from a Pinball the frame it came in was of no use. So I've had to take a spare 19" frame that I've had knocking about for a year or 2 and transfer tube and chassis into that. I know very little about the frame. Came with a 4600 that had a knackered tube. Only ran it for about half an hour in a Defender before selling the chassis and scrapping the tube.
So .....
Is it possible that somehow, somewhere along the way, that the 4600 frame I'm using has become magnetized?
Would that explain the issues I'm still having?
How could I tell if the frame is magnetized?
Could it be de-magnetized?
What are the odds I'm barking up the wrong tree in desperation?
Equites
Chief Sheesher®
35 (100%)
3,329CR
Well no one has responded so I will risk it.
I don't think the problem is the monitor frame, even in the unlikely event of being slightly magnetised, I doubt it would produce those results.
The degauss problem is located at the bottom half right? Is it worse around the bottom end where the tube has less depth?
I'm thinking if you have used a non-standard monitor frame, could it be the LOPT is too close to the tube and wants shielding?
Sheesh.
tb lilley
5 Star
1,686CR
Interesting theory Nad old sprout. I daren't show you how I've mounted the chassis in the frame - but suffice to say if I were to snip a couple of cable ties I'd be able to move the chassis much further away from the tube. I've had a beer. Possibly more than one. So I'm thinking that's a job for the weekend. I'll report back. Hopefully. Hic.
tb lilley
5 Star
1,686CR
Well, I got to the bottom of this today. Pulled the monitor and stuck it on the bench - with a view to adjusting purity / attaching magnets.
As soon as I fired it up I was presented with a 100% prefect picture. So it's not the monitor - it's where it's sat.
Placed the monitor back in the cab and sure enough colours slightly off. Only one source of magnetism in the cab - and that the speakers. In Missile Command the speakers are mounted in the marquee. Removed marquee, perfect picture. So I guess I've got two options - either use this monitor in a different cab or find a way of shielding the speaker magnets.
I've had this before with a different monitor in a different cab. Solved that by simply relocating the speaker - but that's not an option with Missile Command.
Anyone know how / what material is used as magnetic shielding?
G
Guests
Guest
It has to be metal James and has to be attracted to the magnets. Mild steel would be a good place to start.
So, good news and bad news then....I guess I won't be using a 7700 either
PAC-MAN2013-09-21 21:40:00
IDCHAPPY
KANFU Master
9 (100%)
1,523CR
Can't help but glad you got to the bottom of it, fling some lead round the speakers
G
Guests
Guest
That would work but not a proper job
PAC-MAN2013-09-21 20:59:13
tb lilley
5 Star
1,686CR
Don't write off the 7700 for MC just yet Al. Looks like magnetic shielding foil might do he trick. The magnets on those MC speakers are pretty small in diameter. I'm going to try forming a couple of small cones of the foil and slip them over the magnets. I'll let you know how I get on. A chance to experiment if nothing else.
G
Guests
Guest
Enjoying this thread....at least you know where the problem lies.
I look forward to the next instalment!
tb lilley
5 Star
1,686CR
B+Q. Sheesh.
No sir. I'm going to be having it large with nickel-iron alloy, with a touch of copper and a sprinkling of molybdenum for good measure.
Mu metal. 20 bar a roll off of that there ebay.
Equites
Chief Sheesher®
35 (100%)
3,329CR
There is also the option of using a steel shroud around the tube like of a WG6100?
You have a point about B&Q......I'm far too tight to spend there.
tb lilley
5 Star
1,686CR
Yeah - the WG4600 frame I'm using had identical shroud to that used on the 6100 - I didn't bother fitting it at first, but I did put it on a couple of days ago. No change. I think it's because of the weird angle of the marquee and the speakers that are fitted to it. It leans out over the monitor and points down. Ever so slightly.tb lilley2013-09-21 22:25:50
chubsta
547CR
I've got an issue in a cocktail cab where the monitor is rock solid when out of the cab but wobbles when in, there is a large speaker very close to it when the lid is own so I guess it needs shielding from it - do you have a link to the right metal sheet to buy?
