wellon vp 390 problems
virtvic
The Cabaret King
21 (96%)
2,012CR
I bought a new wellon vp 390 programmer.
I have managed to burn some 2732 roms without issue.
I can NOT burn any 2764s or 27128s with it. It comes up nearly immediately with AUTO PROGRAM ERROR and a bunch of error codes etc.
The roms are blanked with my UV lightbox and come up with BLANK OK when you check them in the programmer.
I did notice that the 'modify algorithm parameters' can be changed, but I haven't done anything with that yet as the settings should be set when you choose the correct chip (which I did every time)
I have tried numerous chips and they all do the same. Some of them start to program but fail after a few seconds.
The Chinese forum is bollocks too - their only answer to questions is 'Download new soft' or 'Blank chip'
grobda
1,061CR
My vp280 hates Mitsubishi 2764s, won't program them at all. I ended up burning 4 copies of the image onto a 27256.
Found later it will do other 64's. Some chips the auto-id got it wrong so I used the generic settings. Might be worth a try.
virtvic
The Cabaret King
21 (96%)
2,012CR
I have just had some success on some fujitsu 2764s (2 of them ok) after changing the sh*tty Chinese 9v 0,6a power supply to a switchable one I had lying around. I may even try a different usb cable too.
It still won't touch the Mitsubishi ones - every single one has failed.
(I use the correct maker and model number from the search box - I don't use the auto find)
I'm getting a load of eeproms very soon - I'll try some different ones out.
