Wells Gardner chassis issue
jengineer
49 (100%)
1,205CR
I fitted a new lopt and cap kit to a WG K7000 chassis, chassis works but the brightness is very hard to adjust and its not clear and sharp as other chassis I have had, i had one WG last week that hadn't had a new lopt or cap kit and it had the best picture I had ever seen?
obcd
3,830CR
I assume you have tried a G2 and focus voltage adjustment.
The symptoms you describe can come from an aging tube that had some long burning hours. In such case, usually the brillance increases after a period of on time.
It can help to increase the fillament voltage a little from the normal 6.3 to 6.5 - 6.7V If you go to high, the fillament can break and your tube is trash.
It's only a last resort to get a little of extra life out of an aging tube.
jengineer
49 (100%)
1,205CR
yes the tube isn't the best, it does get worse after a short while and I have to re-adjust but I did try this chassis on the mint tube last week with the same dull symptons
regarding the socket I'll check later
tb lilley
5 Star
1,686CR
gunblade said:
also look out for bad crt sockets,i have had this with corroded focus pin inside the socket itself
Indeed. I sorted a focus problem on a Hantarex 900E this evening - corroded focus pin. Replaced the socket. That's a total of 3 monitors that I've sorted this way now.tb lilley2014-09-15 20:26:24
