Wells k7689
8,284CR
Just picked up
This win fall jamma pedestal cab I have tried to move Convergence ring but they are proving hard to budge ..
Chassis looks to need a cap kit for sure ..is this a convergence rings issue ?
tb2000
3,568CR
Your deflection yoke's got an open winding unfortunately. I'd bet if you pull it off the CRT it'll have corroded in one spot probably round where one of the yoke wedges are. Seen it happen a number of times with CRT's used with WG chassis of that era. I bet the CRT's either a WG's own brand (they use labels very much similar to Orion CRTs) or a Philips (or slight chance it may be a Zenith).
8,284CR
8,284CR
I have two ..
So I will read the yoke on the other ( if it’s ok that is haven’t tested with good chassis )
Second one the flyback had a melt down .
On a positive ..
screens no burn at all
get yoke chassi screen looks like it will be strong
