WG Chassis Compatibility
the-hat
71CR
Hi Guys,
whilst im in a "get things working" mood. Anyone know if I can plug a chassis from a wg k7000 into the tube of a k7201 ?
the neck socket is the same (it appears) and the pinout of the tube looks the same..
- im only asking this as I have a Tapper cab (MCR set). This had major burn when i got it so i put a NOS k7201 monitor into it but the MCR sets dont work well with newer monitors and the picture is all screwy.
Thanks,
tb2000
3,578CR
What model is the other K7000? To be honest, the K7201 isn't really that much newer than any other K7000 and they should all work identically. Have you tried different combinations of h and v sync wires?
the-hat
71CR
turned out i didnt have a k7000 anyway :( could of sworn i did !
I do have a stack of G07 chassis though (tubes have major burn), although i guess they are not compatible with the k7201 tube..
Yeh ive played with all sorts of adjustments, and cap kit'd the monitor. Then i searched on klov and apparently its a known issue with newer monitor and MCR games :/
Thanks guys.
