wg k7000 cap help please
stevebm1
39 (100%)
1,274CR
hi,im recapping a wgk7000,but im confused as to the polarity of caps
c4.c5.c6 all the other caps have the + symbol printed on the pcb,but
these 3 do not,the manual's schematic says NP,so does this mean they can
go in either way?,I stupidly desoldered the old ones first without
taking a picture for reference,as I thought the whole board was marked
thanks in advance
silverfox0786
Beware the Hillman
47 (100%)
2,699CR
not sure as I need to check my own monitor to help you
but as a rule all boards are designed to install in only one direction so in theory all capacitors should be facing the same way, all chips the same way etc etc etc
look at nearby caps and look at the symbol for + and see if they are all one direction
that will give you a clue silverfox07862014-05-13 20:45:49
stevebm1
39 (100%)
1,274CR
thanks for the quick reply.I have done a bit more research and it seems those 3 are non polarised caps,not bog standard ones,hopefully cpc will have some
Equites
Chief Sheesher®
35 (100%)
3,329CR
silverfox0786 said:
i am a little confused
i understand NP is Non Polarised but was unaware that Electrolytic Caps came in non polarised form
The Lilley is right, non polarised Electrolytic Caps are used on some arcade chassis. They look the same as Polarised variants, have a look on Farnell to see what I mean.
RaveN
1,325CR
tb lilley said:
NP = Non Polarised - so can go in either way.
... But they need to be specific NP capacitors, you can't use a normal cap and put it in any way.
Non-polarised caps are for AC-only sections.
